10-13-2020 08:25 AM
I've been having problems with Labview NXG 4.0. It crashed every time when I try to start it. Then I found the error log in my computer.Please help me to location the cause of it.Thanks.
Internal error from LabVIEW NXG
Message:
Unhandled Task Exception
Inner exception 5
Error message:
An item with the same key has already been added.
Exception:
ArgumentException
Suggestion:
Contact National Instruments to report this error
Stack trace:
at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at System.Collections.Generic.Dictionary`2.System.Collections.Generic.ICollection<System.Collections.Generic.KeyValuePair<TKey,TValue>>.Add(KeyValuePair`2 keyValuePair)
at NationalInstruments.EnumerableHelper.AddRange[T](ICollection`1 collection, IEnumerable`1 enumeration)
at NationalInstruments.SourceModel.Catalog.UpdateItem(CatalogMetadataDictionaryBuilder metadataBuilder, XName catalogItemName, IEnumerable`1 metadataItems, Action`1 buildItemCallback)
at NationalInstruments.SourceModel.Catalog.CatalogItemRegistrationStrategy.RegisterExport(IMetadataRegistrationHelper helper, Lazy`2 export)
at NationalInstruments.SourceModel.MetadataRegistrationStrategy`2.RegisterAllAndGetMetadataViews(ICompositionHost host, IMetadataRegistrationHelper helper)
at System.Lazy`1.CreateValue()
at System.Lazy`1.LazyInitValue()
at NationalInstruments.SourceModel.AggregateRegistrationStrategy.RegisterAll()
at NationalInstruments.SourceModel.GenericRegistry.RegisterAll()
at NationalInstruments.SourceModel.MetadataRegistry.GetMetadata()
at NationalInstruments.SourceModel.Catalog.GetMetadata()
at NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport..ctor(ICatalog catalog)
Inner exception 4
Error message:
An exception occurred while trying to create an instance of type 'NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport'.
Exception:
ComposablePartException
Suggestion:
Stack trace:
at System.ComponentModel.Composition.ReflectionModel.ReflectionComposablePart.CreateInstance(ConstructorInfo constructor, Object[] arguments)
at System.ComponentModel.Composition.ReflectionModel.ReflectionComposablePart.GetInstanceActivatingIfNeeded()
at System.ComponentModel.Composition.ReflectionModel.ReflectionComposablePart.NotifyImportSatisfied()
at System.ComponentModel.Composition.ReflectionModel.ReflectionComposablePart.Activate()
at System.ComponentModel.Composition.Hosting.ImportEngine.PartManager.TryOnComposed()
Inner exception 3
Error message:
The composition produced a single composition error. The root cause is provided below. Review the CompositionException.Errors property for more detailed information.
1) An item with the same key has already been added.
Resulting in: An exception occurred while trying to create an instance of type 'NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport'.
Resulting in: Cannot activate part 'NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport'.
Element: NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport --> NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport
Exception:
Suggestion:
Stack trace:
at System.ComponentModel.Composition.CompositionResult.ThrowOnErrors(AtomicComposition atomicComposition)
at System.ComponentModel.Composition.Hosting.ImportEngine.SatisfyImports(ComposablePart part)
at System.ComponentModel.Composition.Hosting.CompositionServices.GetExportedValueFromComposedPart(ImportEngine engine, ComposablePart part, ExportDefinition definition)
Inner exception 2
Error message:
Resulting in: Cannot get export 'NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport (ContractName="NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMap")' from part 'NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport'.
Element: NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport (ContractName="NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMap") --> NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMapExport
Exception:
Suggestion:
Stack trace:
at System.ComponentModel.Composition.Hosting.CatalogExportProvider.GetExportedValue(CatalogPart part, ExportDefinition export, Boolean isSharedPart)
at System.ComponentModel.Composition.Primitives.Export.get_Value()
at NationalInstruments.Composition.FilteringExport.GetExportedValueCore()
at System.ComponentModel.Composition.ReflectionModel.ImportingItem.Cast(Type type, Export export)
at System.ComponentModel.Composition.ReflectionModel.ReflectionComposablePart.SetImport(ImportingItem item, Export[] exports)
at System.ComponentModel.Composition.Hosting.ImportEngine.PartManager.TrySetImport(ImportDefinition import, Export[] exports)
Inner exception 1
Error message:
Resulting in: Cannot set import 'NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService..ctor (Parameter="identifierToCatalogItemMap", ContractName="NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMap")' on part 'NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService'.
Element: NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService..ctor (Parameter="identifierToCatalogItemMap", ContractName="NationalInstruments.SystemManagement.HardwareIdentifierToCatalogItemMap") --> NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService
Exception:
Suggestion:
Stack trace:
Error message:
Resulting in: Cannot get export 'NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService (ContractName="NationalInstruments.SystemManagement.IDiscoveryCreationService(NationalInstruments.SystemApi.SystemManagement.ISystemApiBackEnd)")' from part 'NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService'.
Element: NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService (ContractName="NationalInstruments.SystemManagement.IDiscoveryCreationService(NationalInstruments.SystemApi.SystemManagement.ISystemApiBackEnd)") --> NationalInstruments.SystemApi.SystemManagement.DefaultSystemApiDiscoveryCreationService
Exception:
Suggestion:
Stack trace:
at System.ComponentModel.Composition.ExportServices.GetCastedExportedValue[T](Export export)
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__1.MoveNext()
at NationalInstruments.SystemManagement.AggregateDiscoveryServiceWrapper`1.CreateContentForResource(IDiscoveryResource resource, DiscoveryCreationContext context)
at NationalInstruments.SystemManagement.ResourceUpdateProcessor.CreateContent(IDiscoveryBackEnd updatedBackEnd, IReadOnlyCollection`1 updatedResources, AggregateDiscoveryServiceWrapper serviceWrapper, DiscoveryCreationContext creationContext)
at NationalInstruments.SystemManagement.ResourceUpdateProcessor.UpdateContentForBackEnd(IDiscoveryBackEnd backEnd, IReadOnlyCollection`1 updatedResources, IEnumerable`1 removedResources, DiscoveryCatalogUpdater updater)
at NationalInstruments.SystemManagement.ResourceUpdateProcessor.ProcessUpdate(IDiscoveryBackEnd backEnd, IEnumerable`1 addedResources, IEnumerable`1 changedResources, IEnumerable`1 removedResources, IEnumerable`1 resourcesRequiringRefresh)
at NationalInstruments.SystemManagement.DiscoveryManagerBase.UpdateDiscoveryCatalog(IDiscoveryBackEnd updatedBackEnd, IEnumerable`1 addedResources, IEnumerable`1 changedResources, IEnumerable`1 removedResources, IEnumerable`1 resourcesRequiringRefresh)
at NationalInstruments.SystemManagement.DiscoveryManagerBase.ProcessUpdates(String systemUniqueName)
at NationalInstruments.SystemManagement.DiscoveryManagerBase.<DoDiscoveryAsync>d__46.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at NationalInstruments.SystemManagement.DiscoveryManagerBase.<RefreshSystemCoreAsync>d__45.MoveNext()
10-13-2020 07:45 AM
I've been having problems with Labview NXG 4.0. When I looked under User/Appdata/Local/......Labview NXG 4.0 I find the following error log. Anyone know what the problem could be? Thanks.
Message:
Inner exception 5
Error message:
Exception:
ArgumentException
Suggestion:
Stack trace:
Inner exception 4
Error message:
Exception:
Suggestion:
Stack trace:
Inner exception 3
Error message:
Exception:
Suggestion:
Stack trace:
Inner exception 2
Error message:
Exception:
Suggestion:
Stack trace:
Inner exception 1
Error message:
Exception:
Suggestion:
Stack trace:
Error message:
Exception:
Suggestion:
Stack trace:
10-16-2020 01:14 AM
