Labview Community 2020 Edition Activation
Hey, thanks for writing your solution!
After so many searches and attempts, disabling the TCP/IPv6 on my Wi-Fi adapter allowed the activation to go through.
Thanks again!
SergioR
Message 71 of 123
(3,985 Views)
Wasted hours trying to get this activation to work. Finally found this thread. Unticked IPV6 in my network adapter config and activation worked straight away. Why are we being beta testers for something that should have been properly tested in the first place. I hope this is not a foretaste of what Labview is like in general
Message 72 of 123
(3,919 Views)
Especially when the whole selling point of this activation method was to make it easy to activate!
Bill
CLD
(Mid-Level minion.)
Message 73 of 123
(3,879 Views)
Hi All,
We've released a fix to our activation logic today. Machines running with IPv6 should no longer have issues during activation, and the workaround of disabling IPv6 should no longer be required. We apologize for the complications here and appreciate your patience!
Mackenzie
Message 74 of 123
(3,855 Views)
Awesome!  🙂
Bill
CLD
(Mid-Level minion.)
Message 75 of 123
(3,847 Views)
Thanks!!
SergioR
Message 76 of 123
(3,834 Views)
I needed to switch off IPv6 an turn on IPv4 and then I was able to connect.
Message 77 of 123
(3,751 Views)
Turning off IPV6 worked for me on Labview Community Edition but it did not work for Labview NXG Community Edition so that is still not registered. Thus system is really rubbish. I've sent an email to registration@ni.com for help but of course received no response.
Message 78 of 123
(3,748 Views)
did you run those 2 editions within the same email or NI account ?
if yes then you may have additional problems with the key server .
Message 79 of 123
(3,737 Views)
Same email and downloaded through the NI account whilst logged on. I've sort of given up with NI. I'm reasonably techy and if it's this hard and unsupported by NI just to even register the product for some test use then I think I'll look elsewhere for a solution. They clearly don't want or need the business.
Message 80 of 123
(3,718 Views)
