Labview 8.6 Mobile - Menu Ring Blinking Property Does not work
I am building an application for an HP IPAQ runnings windows mobile 6.0.  In this application Menu Rings with the blinking property are
used.  When run on a Windows XP laptop the blinking attribute functions as expected, but when run on the Windows Mobile 6.0 device the
Menu Rings do not blink.
Is this a bug and/or is there a work around?
jer
(2,867 Views)
Hi Jeremy,
I'm not sure how you created a Menu Ring in a Mobile VI. If you go into your project and create a new target (Windows Mobile 6 device) and then right click that target and select New Mobile VI, you shouldn't be able to choose the Menu Ring as a control. If you cannot choose it as a control, then it won't be supported and therefore any functionality within an executable will be unsupported.
Hope this helps!
Dan Richards
Certified LabVIEW Developer
(2,839 Views)
