We are currently having a problem with the Labview 6.1 Runtime engine and one of your standard Registry vi's.
I have narrowed down the problem to a vi called "Read Registry Value STR.vi".
Basically if I run this vi built into an exe on a pc with just the labview 6.1 RTE installed then I get a compiling error from the lower level DLL.
Pleased take a look at the files included in the Zip file. I have included the Development code (just one of your vi's) and an executable of the same vi.
I have found that using Windows NT with Service pack 6 then there is a problem. I have not tested it on any other environment.
You can also see all three error messages (which continually cycle about 5 tim
es) that appear when you try and run the EXE.
To reproduce the error you will need a Win NT PC with just the Labview RTE installed. It works if you have the Development engine installed aswell.
Please help.....
Regards
Ian Billingsley
Billican
