Labview 2015 - NI 9185 DAQ Assistant Physical Channels
I have a LabVIEW 2015 with which I am using DAQ Assistant (DAQMX 18.6) in the block diagram of my VI.
However, when trying to use the DAQ assistant to create a task to Acquire Signals -  after selecting the type of measurement, in this case Voltage,  I get a message that says no supported devices are found, even though MAX says my NI CDAQ 9185 is connected and running.
Essentially, my LabVIEW program is saying there are no physical channels to be found, if I'm understanding this correctly.
See pictures attached and if anyone could please help, I would greatly appreciate it.
Thanks!
-Al
(2,081 Views)
Hello almu23,
(2,045 Views)
