Labview 2014 - DAQmx Read VI Won't Produce Waveform
I am working on a program for an engineering class and we are supposed to use the Read VI and have it output an Analog Waveform 1 Channel Multiple Samples. I'm using the program our professor designed but the Read VI won't output as a Waveform. I have plenty of options but for some reason it won't output the Waveform format. We are using a DAQ and I downloaded all the needed software (I think) but no luck, even after reinstalling everything.Read VI Outputs.png
(2,252 Views)
Hi Sibley,
maybe because your are using DAQmxBase and not DAQmx?
(2,237 Views)
GerdW,
I looked and I actually had BOTH installed. I uninstalled the DAQmxBase and then found that the full DAQmx was the wrong version,. I had the newest version (19.6) but the newest LabVIEW 2014 can use is 17.4. Everything works now. Thanks for the help!
-SSibley
(2,214 Views)
