09-12-2011 07:42 AM
Labview crashes on startup. I get this message: "Labview 10.0 Development System has stopped working." I don't get any further than this.
I have 95 computers running Windows 7 64-bit Enterprise. To install Labview on these I use the automated installer with these options: "/q /acceptlicenses yes /r:n /applyspecfile k:\zfdmsi\Labview2010\yellow1\".
This was working on Windows XP. I have tried to install Labview manually on one of the windows 7 computers and it works fine.. But I cant do that on 95 computers...
Any ideas why it's crashing?
Thanks in advance.
09-13-2011 02:53 AM
I tried again installing with CD's on a new computer today and I get this message: "Error: This installer needs access to "My Documents". However, this location "m:\HiTfiler\My Documents\" is not available. Ensure that this directory exists and is available and run the installer again."
This path does exist though.
09-13-2011 08:40 AM
You have the drive letter listed as "m". Is that correct?
Is that a network drive? Sometimes trying to establish connections with network drives are more time consuming then it would be a local hard drive, and the installer is not getting a response from the M drive in time.
09-14-2011 02:11 AM
Yes, m: is a network drive. We have a local policy on all workstations redirecting My Documents to the M: drive.
I got the issue resolved by installing Labview 2010 SP1 🙂
