> Problem: When trying to change cursor position programatically using
> attribute notes, the cursor position will not change.
> I found this in the knowledgeBase. Solution: Unlock the cursor.
> Cursor position attributes are read-only when the cursor is locked.
> Liz
> Still looking for answer of a way to initialize 100 cursors with
> Cursor legend.
If you want to do things programmatically, like set the cursor text to
match the X or Y value of the point, read the value, format the string
and write it to the name of the cursor.
If you want to init 100 cursors interactively, you can popup on the edge
of the cursor legend and show the index. The cursor legend is simply an
array of clusters of cursor info. Set the index to 99 and type in a
name, value or something else. This will allocate 100 cursors. I'm not
sure if that is what you meant.
Greg McKaskle
