LabWindows CVI "There is no disk in the drive. Please insert a disk into drive"
This morning when I fired up LabWindows CVI v8.5. A pop up panel appeared LabWindows CVI "There is no disk in the drive. Please insert a disk into drive D :" appeared when running cvi.exe. I could click on the pop up several times and make it go away. When I get to my application and try to run it the same pop up panel appears. Again I can make it go away but it persists no matter what. I don't remember doing anything different or strange yesterday. Anybody have a clue ? I searched here and found a similar issue with a LabView post but I think this needs a different fix. Anyway, please help.
(3,283 Views)
Another discovery. When I place a blank CD int the drive the "There is no disk in the drive. Please insert a disk into drive" does not appear.
(3,278 Views)
Hi leichner,
Would it be possible for you to post a screenshot of this message to this thread?
Also, do you get the same behavior if you try to open a CVI example? Instead of launching CVI from cvi.exe, go to an example and double-click on the .prj file. This should open CVI for you with this example program loaded. Let me know if you still get this message.
Thanks!
Manooch H.
(3,249 Views)
