LabView program times out before HP35670A completes long sweep. Is there a timeout in one of the the instrument driver VI's?
My LabView program times out before HP35670A completes long sweep.  Is there a timeout in one of the the instrument driver VI's?
I want the program to wait for the 35670A to finish the sweep.
(2,341 Views)
And which VI might that be?
(2,325 Views)
Do you have Context Help turned on? You can simply browse through the fuctions to see which might have a timeout input. It took me only a short while to find 'Act Wait OPC'. You have not posted your code so I have no idea what functions you might be using.
(2,316 Views)
Thanks for the help.  Changing Actn Wait OPC timeout doesn't resolve issue.  The standard vi's with the instrument driver don't seem to wait for the 35670A to finish a scan.  I want the program to poll 35670A status and when the scan is complete, transfer trace data.  My program sequence is Initialize, Actn Start Stop Cont then Data Coord Trans Data.  Other settings like channel configuration, instrument mode, etc are set manually.
(2,291 Views)
Have you tried increasing the VISA timeout?
=== Engineer Ambiguously ===
(2,284 Views)
