LabView locks up when dialog box is closed
Whenever I am testing a project in LabView Application Builder, I currently have a button that when clicked opens up a dialog box. When I close the dialog box, the app becomes unresponsive and nothing within the project works again until I restart the the test run.
Has anyone experienced this, and what might be causing the issue?
Message 1 of 8
(396 Views)
Can you show us a picture of this dialog box?  Is it something you created or something that is a part of LabVIEW?
Message 2 of 8
(363 Views)
Does this happen once your run the built application or something that happens during the build?
If it is part of your program, I assume (but you don't really say!) it does not happen if you run in development mode.
Can you explain the definition of "nothing". How exactly do you "restart the test run"? Do you need to close and reopen the project?
I suspect a dataflow issue or resource contention, Hard to tell without seeing any code.
LabVIEW Champion. It all comes together in GCentral GCentral
What does "Engineering Redefined" mean??
Message 3 of 8
(341 Views)
Closing a dialog box, especially one you've made yourself, only closes the front panel. If the VI waits for a button press it'll continue waiting ... forever. Make sure you handle Events as Application Quit and Front panel close, or make sure it's not closable.
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
Message 4 of 8
(296 Views)
Obviously, everybody understands your question differently, because it is ambiguous and it is not clear what information is relevant or irrelevant.
Please define exactly what you mean by "... testing a project in LabView Application Builder ... ". Application builder is for building, not for testing projects! Typically one tests VIs or built executables. I am not even sure what testing a project means.
Is this one specific scenario where the problem occurs and it does not occur in any other test scenario?
Describe exactly what you are doing and under what conditions the problem occurs and under what condition everything works fine..
Message 5 of 8
(285 Views)
Actually, just making sure the VI runs to completion when you dismiss it should be all you need.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(276 Views)
Yes, that's the general way of describing it. 🙂
Message 7 of 8
(253 Views)
The point was that if closing the panel is allowed ([X] in upper right corner) or a "panel close?" not correctly handled with an event, and the window is closed by pressing [X], the VI can never come to completion if that requires user interaction.
Message 8 of 8
(243 Views)
