LabView and SysTec GW-003-10 CAN-Ethernet Gateway?
Highlighted
Is anyone using a SysTec GW-003-10 CAN-Ethernet Gateway with LabView?  Specifically, I'm thinking about using one with a JJ X-ray stepper motor controller.  Thanks in advance!
Best wishes,
Will
(728 Views)
Hello Will,
In case no one posts who has directly already done this, is there anything in particular that you are having difficulties with?  Are you looking for prebuilt code or maybe just an idea of how hard this will be to program.  If you're looking for the specifics, let us know and we'll try to help you out.  There are a few TCP example VIs in the Example Finder that give a good idea of how to set up TCP communication.  Hope this helps!
ColeR
Field Engineer
(712 Views)
