LabView VB6 Dll Interfacing causes memory leak
I added this code to the general part of the code:
Private Declare Function DSDisposeHandle Lib "lvrt.dll" (LStrHandle as Long) as Integer
And after I copy the the data in VB I added this code:
Dim dispose as Integer
dispose = DSDisposeHandle(StringHandle_detector)
dispose = DSDisposeHandle(StringHandle_ext)
but nothing has changed. Have I missed something here?
If I want to create a Pointer to a C string instead - how do I do this in vb6?
Best,
Julian
edit:
As pointers have to be adressed ByVal I changed the line to :
dispose = DSDisposeHandle(ByVal StringHandle_detector)
dispose = DSDisposeHandle(ByVal StringHandle_ext)
Which did the trick 🙂
Thanks very much!!
Message 11 of 13
(1,121 Views)
My VB knowledge is almost non existent but wouldn't
Private Declare Function DSDisposeHandle Lib "lvrt.dll" (ByVal LStrHandle as Long) as Integer
do the same?
Rolf Kalbermatter
My Blog
Message 12 of 13
(1,105 Views)
Yes.
The latter would also be the more elegant way of implementing it - directly in the definition.
Best,
Julian
Message 13 of 13
(1,100 Views)
