08-21-2021 11:29 AM
the title says it all: I have not been able to activate the 2021 version, despite following all the suggestions posted on the forum (e.g. deactivating ipv6, firewalls, and switching networks). I only managed to get an installation working by deleting everything and installing the 2020 SP1 version.
posting this for others with the same issue (also see https://forums.ni.com/t5/LabVIEW/LVCE-activation-issue-again-despite-following-all-forum/m-p/4173596...).
Best,
tb
Solved! Go to Solution.
08-21-2021 01:39 PM - edited 08-21-2021 01:47 PM
Please elaborate: 1. What do you mean by "delete everything"? 2. As for the final result did you manage eventually to activate the 2021 version or had to settle for 2020SP1? I have 2020SP1 installed and working but can't activate 2021.
08-23-2021 08:02 PM
Same problem here. I have the 2020 SP1 community edition installed and activated and working fine. Just installed the 2021 community edition but cannot activate it.
08-23-2021 10:54 PM
with "delete everything" i meant "i used the package manager to remove all installed packages" prior to installing the 2020 SP1 version.
I have not managed to activate the 2021 version in the end. I settled for 2020 SP1.
