LabVIEWCLi -OperationName RunUnitTests Exit Code = 0
Is it possible for the LabVIEW CLI to exit with 0 (zero) when executing Unit Test even though one ore more of the units test fails. It is a challenge when executing a multi stage pipeline that is running on a repository.
LabVIEWCLi -OperationName RunUnitTests ....
As I see it the LabVIEW CLi should only exit with a code different from zero if there is a Run Time error
(738 Views)
I found some information in KB that will be of use.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019TwfSAE&l=en-GB
At the bottom of this page:
"Make sure that you are following the formatting in the Predefined Command Line Operations guide for the RunVI. A few things to remember:
  • The "Command line arguments for the VI" is a string array
  • The "CLI for LabVIEW exit code that the VI returns" will return either a 0, 2 or 3 depending on the circumstances. You will choose which value to output.
  • The "Output or error information to include in the CLI for LabVIEW console or log file" is a string"
Kind regards,
Michael
(702 Views)
Hi Michael
In this case I am not in control of the return code because I am using a predefined command RunUnitTestsSmiley Wink
The Exit code from CLI should only be different from zero if there is a run time error, as I see it.
(691 Views)
Hi kjeld,
You can create the custom operation as mentioned here:
http://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/cli_creating_operations/
(678 Views)
Hi
Yes I know that the possibility is there to make a custom operation; which also can be the next step, but we would like to use as much tooling out of the box so we doesn't have maintain it.
(659 Views)
