Do you have the formula but problems creating a graph?
See if this can give you some ideas (make sure you fully understand every part and can explain it to the teacher!)
Again:
  • Don't use a subject of LabView in a LabVIEW forum (and use the correct lettercase!)
  • Don't put your question inside code tags.
  • You can embed images directly into posts, but please use filenames with the Latin alphabet for attachments.
  • Talk to your classmates.
Message 21 of 40
(1,272 Views)
Sorry to bother you, you can make 2 more schemes if it doesn't bother you, if you have time, if not, just refuse, I'll understand everything.You need to make a graph of a given area.
Message 22 of 40
(1,246 Views)
foreverxyoung_0-1762282886074.pngforeverxyoung_1-1762282902268.pngforeverxyoung_2-1762283045606.png
Привет, ребята! Подскажите, пожалуйста, где я ошибаюсь в формуле? Мне нужно построить график, как на первом фото. Не могли бы вы прислать мне правильную формулу?
Message 23 of 40
(1,289 Views)
You won't learn LabVIEW by having us do your class exercises for you.  Do them yourself, and when if they don't work, post them (we prefer that you post VIs, but many of us, myself included, aren't running LabVIEW 2025, so you should "Save for Previous Version" and specify 2019 or 2021 for reaching more of us "old-timers") and we'll criticize your efforts so that you can "learn from your mistakes"..
Message 24 of 40
(1,223 Views)
  • I recommend to post in English.
  • All you probably need is one more condition, right?
(There has been a flurry of posts from your classmates about this and similar problems. Maybe sit together and discuss.)
Message 25 of 40
(1,271 Views)
This cracked me up! haha. Thanks!
Message 26 of 40
(1,267 Views)
Sorry, I thought I wrote it in English, but it immediately translated into Russian. I don't know the people who posted the problem; maybe we all follow the same curriculum. If it's not too much trouble, could you tell me what's wrong with the formula?
Message 27 of 40
(1,257 Views)
You are missing the condition that a point also needs to be above the line going through points [-3,0] and [0,-3].
Can we assume you fully understand the rest of the code that you apparently mostly copied from here?
Message 28 of 40
(1,203 Views)
What kind of graph?
To reproduce the shaded areas, continue where we started and just modify the logic.
First graph:
A point needs to be below the parabola AND above that straight line if x is negative and above otherwise.
(I assume you know the formula for the two curves, right? Simple math!)
Second graph:
For each circle: points are inside if their distance to the center is less that the radius.
For the square, points are inside if x and y are in the correct range.
The rest are simple boolean operations:
  • upper left area: inside that circle AND inside square
  • Lower right area: inside that circle AND NOT inside square.
We gave you all the tools, now just assemble it into code!
Message 29 of 40
(1,195 Views)
Message 30 of 40
(1,201 Views)
