LabVIEW with Kistler 5074 charge amplifier
Hello all,
I've recently bought a LabVIEW license to read the data from my Kistler charge amplifier type 5074A.
https://www.kistler.com/en/product/type-5074a/.
I have had experience with LabVIEW before, but only with simple operations. e.g. Mindstorms NXG.
The amplifier is configured on Ethernet/IP. I have an EDS file from the Kistler site an a MAC address on the device.
I would like to make a VI to communicate with the amplifier and read the sensor data.
Can someone help me with this problem?
Many thanks.
(5,941 Views)
     I tried to go on the Web and see how to get data from the Kistler amplifier, but was not successful.  I have had the experience of getting data from Mettler Balances through their TCP/IP outputs -- Mettler treated them as VISA ports (VISA over TCP/IP), so we just configured VISA for TCP/IP, sent it Balance commands, and started reading Weight messages.
     Do you have a manual that describes how your Amplifier passes data back over TCP/IP?  How does it appear if you connect it and then open MAX and look for it under Devices and Interfaces?  You should do some experiments with Test Panels under MAX and see if you can get it to send you information -- use the commands that I hope Kistler provides and see if you get any responses.
     Let us know what you find.  If you do have such a manual, and if it has a PDF version, attach the manual, I'll look up my old code, and we may be able to make some progress.
(5,905 Views)
Dear Bob,
Thanks for your reply.
I will try to do some experiments.
I've attached the manual.  I think 4.2.1 and 4.2.7 are the paragraph's you're looking for.
M. Mombarg
(5,896 Views)
Thank you for providing the manual.  It appears that this device uses its own protocol, and does not seem to have an accessible API that you could use (like a VISA Interface like the Balances I used).  I don't have any more suggestions to make other than to contact Kistler directly.
(5,888 Views)
Accepted by topic author Mombis
Thank you for your reply.
I will contact the sales engineer I spoke with to ask for a solution.
If i get the help I need, I might post it on this forum to help others.
M. Mombarg
(5,881 Views)
Hi Mombis
Did you find a solution how to make a VI to communicate with the amplifier and read the sensor data?
I aim to use LabView to read my sensor data using a Kistler 5074 charge amplifier, too.
Many thanks in advance,
Lukas
(3,566 Views)
@Spirlu wrote:
Hi Mombis
Lukas
Hello, Lukas.
     Mombis hasn't visited the Forums for more than 2.5 years.  It is unlikely that he (or she) will see your request for help.  You might follow the suggestion to contact Kistler for help with reading data from this amplifier using LabVIEW -- they must have some form of output, maybe even something digital.  Is it possible that this is discussed in the documentation you received with your Kistler 704?
(3,555 Views)
