LabVIEW subscription model for 2022
@Yndigegn wrote:
So you are one of the not-so-many lucky one's having a LV 2022 Q3 version on a perpetual basis. I guess most got their perpetual LV versions stopped before LV 2022 Q3.
LV 2022 Q3 supports the LabVIEW AddOn concept. So you can install all the upcoming drivers. No need to upgrade LV. That is splendid.
So keep programming ..
2022 Q3 is also the first version to officially support Windows 11. Hopefully that means I can stick with it as long as possible, waiting for Windows 11 to no longer have support before we will have to evaluate what we do next.
Message 751 of 852
(1,141 Views)
Hi
Sorry, my YES hat shadowed for the reality. Some drivers and modules did not manage to get AddOn support in LV 2022 Q3, but only in a later LV version, including RIO related :
Driver and Toolkit Addon Support
See the table below for compatibility information. The driver version shown in the table is the first driver version to include Addon support for the indicated LabVIEW version. LabVIEW compatibility information can also be found in individual driver and toolkit readmes.
All drivers in the table below are expected to be available with Addon support. Support will be incrementally released through 2022 and 2023. An exception to this is RFmx, which is not currently listed in the table. Although we expect to release RFmx with Addon support eventually, the timeline is not yet defined.
Driver/Toolkit LabVIEW 2022 Q3 Addon Support LabVIEW 2023 Q1 Addon Support
Automotive Diagnostic Command Set Toolkit 2022 Q4 2022 Q4
ECU Measurement and Calibration Toolkit 2022 Q4 2022 Q4
FlexRIO Not available 2023 Q1
Industrial Controller Device Drivers Not available 2023 Q1
IVI Compliance Package 2022 Q3 2022 Q3
LabVIEW Electrical Power Toolkit Not available 2023 Q3
LabVIEW Instrument Design Libraries for High-Speed Serial Instruments Not available 2023 Q3
LabVIEW Instrument Design Libraries for IF Digitizers Not available 2023 Q1
LabVIEW Instrument Design Libraries for Reconfigurable Oscilloscopes Not available 2023 Q2
LabVIEW Modulation Toolkit Not available 2023 Q3
LabVIEW OPC UA Toolkit 2022 Q4 2022 Q4
LabVIEW Sound and Vibration Toolkit 2023 Q3 2023 Q3
NI CompactRIO Not available 2023 Q1
NI R Series Multifunction RIO Not available 2023 Q1
NI-568x Driver Software Not available 2023 Q1
NI-5690 Driver Software 2023 Q2 2023 Q2
NI-845x Driver Software 2022 Q3 2022 Q3
NI-DAQmx 2022 Q3 2022 Q3
NI-DCPower 2022 Q3 2022 Q3
NI-Digital Pattern Driver* 2022 Q4 2022 Q4
NI-DMM 2022 Q3 2022 Q3
NI-Embedded CAN for sbRIO Not available 2023 Q2
NI-FGEN 21.8 21.8
NI-HSDIO 2022 Q4 2022 Q4
NI-Industrial Communications for CANOpen 2022 Q4 2022 Q4
NI-Industrial Communications for DeviceNet 2022 Q4 2022 Q4
NI-Industrial Communications for EtherCAT Not available 2023 Q1
NI-Industrial Communications for Ethernet/IP 2022 Q3 2022 Q3
NI-RDMA 2022 Q4 2022 Q4
NI-RFSA Not available 2023 Q1
NI-RFSG Not available 2023 Q1
NI-SCOPE 2022 Q3 2022 Q3
NI-SLSC 2022 Q4 2022 Q4
NI-SWITCH 2022 Q4 2022 Q4
NI-Sync 2022 Q3 2022 Q3
NI-USRP Not available 2023 Q3
NI-VISA (excluding macOS) 2022 Q3 2022 Q3
NI-VISA for macOS 2022 Q4 2022 Q4
NI-VRTS Not available 2023 Q2
NI-XNET Not available 2023 Q1
PXI Platform Services 2022 Q3 2022 Q3
PXIe-7899 API and Design Files Not available 2023 Q2
RMX-400x Electronic Load Driver 2022 Q4 2022 Q4
RMX-410x Power Supply Driver 2022 Q3 2022 Q3
RMX-412x Power Supply Driver 2022 Q4 2022 Q4
Switch Executive Not available 2023 Q1
System Configuration 2022 Q3 2022 Q3
Vision Acquisition Software Not available 2023 Q1
Vision Builder for Automated Inspection Not available 2023 Q3
Vision Development Module Not available Not available
* The FPGA components of NI-Digital Pattern Driver 2022 Q4 did not receive Addon support. This support was added in NI-Digital Pattern Driver 2023 Q1. Using NI-Digital Pattern Driver 2022 Q4, customers with LabVIEW 2023+ will not be able to compile bitfiles for NI-Digital instruments. Customers using NI-Digital Pattern Driver 2022 Q4 without LabVIEW FPGA Module 2023+ installed will not be able to deploy bitfiles in LabVIEW 2023+.
Message 752 of 852
(1,114 Views)
Windows 11 bombshell...
Just tried installing LV2019 on new windows 11 PC.. After installation got 'bitlocker' stuck at boot.
Could fix it by rolling back to restore point.
Checking LV compatibility. Turns out windows 11 is only supported 2022 onwards.
Just at the time subscription started..
Anyone experience with that?
25+ years long fan of LabVIEW. Move to Emerson looks to be for the better! See the last posts in subscription model thread.
Message 753 of 852
(860 Views)
I installed LabVIEW down to 2009 on Windows 11 Virtual machines with no major problems. Did you also install DAQmx or other hardware drivers? They should not cause major problems with Windows 11 itself but older versions might not always fare will with latest AMD or Intel Core CPUs and/or chipset. Windows 10 system drivers do not support some of the more recent chipset features so that they do not get enabled even on this new hardware under Windows 10, but Windows 11 may switch on features that older drivers were never able to encounter before they were released.
Rolf Kalbermatter
My Blog
Message 754 of 852
(849 Views)
"Did you also install DAQmx or other hardware drivers?"
That probably was the problem. Used the package manager to install LV2019, including DAQmx and drivers. After that bitlocker locked my system. Could reset to earlier restore point.
Tried again but this time disabled DAQmx and drivers in first installation dialog. Installed fine after that. (I'll try installing DAQmx and serial driver seperate via package manager, just the newest version.
If don't come back to this topic (I expect it), that worked fine.
Thanks!
Message 755 of 852
(798 Views)
The latest version of DAQmx that will support LabVIEW 2019 is DAQmx 2022 Q4.
Rolf Kalbermatter
My Blog
Message 756 of 852
(760 Views)
It looks like Perpetual Licensing is coming back!
Select Your NI LabVIEW Edition
GCentral
Message 757 of 852
(637 Views)
Perpetual licenses have always been available, all you had to do was ask and be persistent.
Message 758 of 852
(629 Views)
So the next question is... Can we get an annual SSP for that perpetual developer license?
Message 759 of 852
(585 Views)
Yes, development perpetual licenses have SSP included for the first year and you can renew regularly in the following years
Ahmed Eisawy | Director of Test Software Commercialization | +1 (503) 453-9178 | ni.com
Message 760 of 852
(583 Views)
