LabVIEW stops at initialise.vi and not responding after clicking stop
Highlighted
The background is that I am using AFG3022B Signal generator from Tektronix and connect it through USB-USB to my PC (AFG3022B I had only had a USB port to connect with).
I want to write a LabVIEW program that I can use it to generate certain output power at a certain frequency.
The basic flow is that initialize > setting frequency and power > enable output > close vi.
I did it in an open loop without iterations. It works fine.
When I create a for loop and run, after a few iterations, I can see from NI I/O trace that it stops at VISA open, as you may check from capture1.png.
Then I went back and check the normal status, as you can check from capture2.png.
Apparently, the normal status will repeat twice the visa resource name "USB::XXX" and give 0. Then everything continues to work.
The unknown status shows only one time of visa resource name "USB::XXX" and give nothing. Then LabVIEW stops there, and not responding when I try to stop the program.
please share your idea on how to fix this problem.
Message 1 of 12
(336 Views)
Highlighted
updated the pngs
Message 2 of 12
(334 Views)
Highlighted
Could you share your code? It is awfully difficult to see errors in code that cannot be seen.
Message 3 of 12
(285 Views)
Highlighted
in the zip file, it includes the driver I find in NI website, the vi file I create and captures.
Message 4 of 12
(282 Views)
Highlighted
I also encounter other problems. Sometimes I try to increase waiting time, then some errors will not appear, but in the end, there will be an error waiting for me.
Like sometimes it will report:
1. "Error -1073807343"
Possible reason(s): VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
2. error "-1073807302"
possible reason is listed as "VISA: (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set in an inconsistent state)."
3.Error-1073807297.
possible reason is like "format string is invalid".
just a simple labview program. Maybe the driver itself is faulty?
Message 5 of 12
(271 Views)
Highlighted
Can you save your VI for a previous version of LV. Many of us aren't running on 2020 (I am still on 2019 personally)
Message 6 of 12
(266 Views)
Highlighted
I try the "save for previous version" and select 18.0.
hopes it works. thanks for your help.
Message 7 of 12
(256 Views)
Highlighted
Accepted by topic author Tony@NTU
I can't open the driver VI's because they are still for LV 2020.
A couple of observations which might solve your problem, even if they don't I recommend that you do them.
Only initialise and close your VISA reference once. Leave it open whilst you are using it.
In other words, open your VISA reference - in a loop perform your tasks - once you are finish end the loop and close the reference.
It may be worth putting your initialise VISA reference in a loop to retry connecting if it fails but this shouldn't really be necessary and may just be a plaster for a bigger problem.
See a suggestion attatched
Message 8 of 12
(252 Views)
Highlighted
Thanks. I take a look first.
Also, the driver can be found from:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=6EC36E806C121C7AE04400144FB7D2...
I download it again and it's for 2018 as it states.
please take a look.
Message 9 of 12
(242 Views)
Highlighted
This is the most likely thing to fix the issue.  There is absolutely no point in constantly opening and closing a connection in a normal operation.
GCentral
Message 10 of 12
(226 Views)
