LabVIEW source code version of the NI-DCPower Soft Front Panel
I am working with an NI PXI-4130 SMU. There is a soft front panel exe called the "NI-DCPower Soft Front Panel" that can be used to control this instrument. I was wondering if there is a LabVIEW source code version of this driver?
Jim Haas
(2,345 Views)
Accepted by topic author JHaas
Jim,
afaik there are no LV source codes provided for the Soft Front Panel. But there are some LV examples which come close to the features of the SFP. So i suggest you to dig into the examples you find in the Example Finder.
Hardware Input and Output >> Modular Instruments >> NI DCPower.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,333 Views)
