LabVIEW softmotion + solidworks errore: (Hex 0x80DF001E) The deployment plug-in for this item cannot be found. Verify the proper software is installed.
Buon giorno a tutti!
Scrivo questo messaggio perchè è due giorni che stò impazzendo per riuscire ad utilizzare labvew w solidworks come mostrato in mille tutorial....per fare le cose semplici hoi creato un assieme composto da due semplici parallelepipedi ai quali sono assegnati 3 motori lineari secondo gli assi principali. Come da istruzioni importo il modello e setto gli assi. Già qui nasce una discordanza: il pannello di impostazione dell'asse è diverso da quanto visto in vari tutorial in quanto manca la parte destra del pannello di solidworks....in ogni caso riesco a settare tutto come indicato. Appena eseguo deploy esce questo errore:
LabVIEW:  (Hex 0x80DF001E) The deployment plug-in for this item cannot be found. Verify the proper software is installed.
Qualcuno saprebbe gentilmente darmi qualche consiglio?
Grazie
Alessandro
(3,720 Views)
I'm sorry....I didn't see that this forum is in english....translation:
Good morning everyone!
I write this message because it's two days that I'm crazy to be able to use solidworks labvew and as shown in the tutorial .... to make things simple I created an assembly composed of two simple parallelepipeds which are connected to three linear motors according to the principal axes . Then I imported the model and set the axes. Even here there is a difference: the setup panel axis is different from that seen in various tutorials because there is no the right side of the panel solidworks .... anyway I can set everything as shown. When I run deploy get this error:
LabVIEW: (Hex 0x80DF001E) The deployment plug-in for this item can not be found. Verify the proper software is installed.
Someone would know please give me some advice?
thanks
Alessandro
(3,719 Views)
Iive installed labview 2011 whith softmotion and real time toolkit....now the axe pannel is ok....but labview doesn't open, see or comunucate with solidworks assembley...
Please, someone could help me?
(3,702 Views)
Please could help me....it's for my phd research and it's very urgent...
(3,690 Views)
Ciao Alessandro,
sono Valerio un AE di NI Italy.
Non ho capito bene, il tuo problema adesso qual'è esattemente? che errore ottieni?
(3,665 Views)
Ciao Valerio...grazie mille per la risposta ma ho risolto il tutto reinstallando Windows, labview e solidworks...ora funziona!
Tuttavia approfitterei per chiederti un ulteriore aiuto su un altro mio post altrettanto importante:
http://forums.ni.com/t5/LabVIEW/Softmotion-Read-from-solidworks/td-p/2346934
Ti ringrazio anticipatamente!!
(3,656 Views)
