05-08-2007 02:41 PM
05-08-2007 03:29 PM
Define 'garbage'. Is the reading incorrect, incomplete, or something else? Is the string indicator from the VISA Read set to hex display or '\' Code Display? What is the command you are sending? What type of connection do you have - serial, serial, etc?
If you could post the VI you wrote after running it, doing a Make Current Values Default, and then a save, it would help to actually see what is being returned.
05-08-2007 03:44 PM
yeah, that was grossly uninformative. so I have a TCPIP connection to a spectrum Analyzer. I am querying for waveform data in int,32 format. The data block returned in MAX and VISAIC have the correct header eg. #42204 and data in the specified format . However, in LabVIEW, the data block is without the #, and the block contains int 32 data, ascii data and possibly a third data format.
hope this helps
05-08-2007 03:56 PM
05-08-2007 04:13 PM
05-08-2007 04:42 PM
05-08-2007 06:41 PM
