07-07-2011 10:03 AM
07-07-2011 10:07 AM
10-31-2012 04:38 AM
Hi Rach,
Did that work out for you, as I am having a similar issue with my DMM4020. The baud rate is set to 9600 which is supposed to be fast enough for simple data acquisition, and as you have mentioned the data rate of the unit is almost 100 samples/sec, but when you control it thru labview you end up waiting for 5-6 seconds which is really irritating !
So please advise whether the suggested solution have worked out for you.
Thanks in advance...
11-01-2012 09:11 AM
Hello Adserhan,
Thanks for posting at NI forums! The original question seems to be resolved since it has a marked reply as the solution.
Best Regards,
Alina M
Applications Engineering
