LabVIEW installation makes Windows 11 boot into BSOD in Parallels Desktop on Apple silicon Macs
Steps to reproduce:
NB: The issue doesn't persist in Parallels Desktop 19.4.1 because Parallels did some tweaks but the issue might occur again and exists in other Parallels Desktop versions.
1. Install a new Windows 11 virtual machine in Parallels Desktop on Apple silicon Mac by clicking 'Get Windows from Microsoft': https://kb.parallels.com/125375
2. Download a 32/64-bit installer of LabView: https://www.ni.com/en/support/downloads/software-products/download.labview.html#521715 (Base, Full, Professional; 2024 Q1)
3. Start the installation of LabVIEW
4. Once the installation is completed and restart of Windows is offered, restart Windows
Expected results:
Windows restarts and the LabVIEW app is completely installed.
Actual results:
Windows shows BSOD window and isn't usable
(2,131 Views)
So, in a nutshell, this was a bug in parallels and NI would have very little control over that.
(2,118 Views)
Parallels applied a workaround to fix the issue for its customers but the issue is that LabVIEW loads its x86 drivers prior to the Windows drivers that makes Windows BSOD.
(2,066 Views)
Whatever that means...
This does not seem to be a problem for windows running on hardware, so the issue is still with parallels and fortunately they were able to fix their bug.
It is a bug fix, not a workaround, IMHO. 😄
(2,062 Views)
Did you do a LabVIEW install or a full LabVIEW + NI-DAQmx, + NI-VISA + NI-climbim and NI-climbam and whatever else adding up to a 50GB install or something like that?
A LabVIEW IDE install only should NOT install anything that could ever BSOD your Windows installation. NI-DAQmx, NI-VISA and NI-this and NI-that installs kernel device drivers that are compiled for Intel x64 CPUs. Windows 11 ARM does not provide full CPU virtualization for x64 software. Especially the kernel environment can not properly handle x64 virtualization.
Rolf Kalbermatter  My Blog
(2,032 Views)
Hello everyone,
I’m experiencing the same issue.
I created an installer for my LabVIEW application, and after installing it on a Windows 11 laptop, the system shows a blue screen upon restart. It seems the LabVIEW installer itself is causing the blue screen problem on Windows 11.
Kindly guide me how resolve this issue.
(346 Views)
@GYALI77 wrote:
Hello everyone,
I created an installer for my LabVIEW application, and after installing it on a Windows 11 laptop, the system shows a blue screen upon restart...
It’s probably the same disaster: Re: Labview Download Crashes Computer and Causes Blue Screen
(335 Views)
