11-29-2006 11:39 AM
11-30-2006 05:41 PM
05-21-2010 09:11 AM
Actually I do have drivers for the EOSI Laser which is the same laser but from the time before Newport bought EOSI. However, I am missing the manual for the laser, so if you are still interested after all this time in the driver I can send it to you. Perhaps you could send me a photocopy of the manual in return? Uli
05-27-2010 09:36 AM
All,
Here is a link to a clean photocopy of the EOSI 2010 laser manual:
https://wiki.brown.edu/confluence/download/attachments/29406/Diode+Laser+Manual.pdf?version=1
You can also Google it using "EOSI 2010 laser" and find the maual in the link that says: "EOSI tunable laser diode systems and accessories are guaranteed for a period .... the 2010 laser diode. The first method is more sensitive but requires both .." Good hunting.
Sincerely,
John Zehnpfennig
U-Michigan Optics Lab
05-27-2010 09:47 AM
Dear John, thank you very much, Uli
08-23-2016 04:16 PM
OK. this is a long time ago, but maybe you still are there ... I picked up an EOSI 2010A like yours about a month ago pre Newport stock too and I also have a manual ... I am looking to both obtain said driver as well as the wavelength, grating and range of this device [sn00266] parameters ... can you advise? Thanks Grant
08-23-2016 05:02 PM
presently I am not at my home institution and I would need to ask a collegue to dig out the labview drivers. But I am sure we do have them somewhere.
Concerning wavelength, grating etc.: Does this mean you do not have the specs sheet? It should be inserted in the manual.
Cheers, Uli
08-23-2016 05:05 PM
Cheers, Uli
