10-19-2017 07:24 AM
i have a problem, from time to time when i program, a VI will be corrupt.
As soon i close the vi, LabVIEW crashes. I have to start LV again, i can program this VI also run it, but as soon i close the VI again, LV crashes.
System:
W7 Pro
LV2013 + DSC+FPGA
10-19-2017 08:32 AM
Probably the only thing we can get from that is: can you post F2.vi?
Or at least give some hints about what's going on in the VI. DLL's, .net or such? Anything might help...
10-19-2017 07:46 PM - edited 10-19-2017 07:46 PM
Looking at the call stack I actually found a bug report which seemed pretty similar. It had an attached VI which would open and run in 2013 but would crash when closed. The last ~20 calls of each call stack were identical so while it's not conclusive I'm pretty optimistic.
They found that if they copied the contents of the VI over to a new blank VI the old one would still crash but this new one would seem to work fine.
If you are reading/writing to shared variables or have FP items bound to PSP tags, it seems like something might be messed up with the PSP link although it wasn't clear how it got into this state in the first place (or really how to fix it). In the example I found, there were FP controls which were bound to PSP variables but the path was just blank (It doesn't seem possible to actually configure a FP item this way which is probably part of the issue here).
If this random shot in the dark didn't seem to hit the mark I would agree with wiebe@CARYA that we would need the VI.
10-25-2017 09:45 AM
Dear Matt,
I have done many tests with the VI after you mail.
After deleting a few FP elements the problem was solved.
But when i put some new FP elements or copy, the problem was there again.
At the end i copy all FP elements to a new VI, prepare the program.
Now it looks good, but how long?
I could not fined the real fault.
Attached the vi
Best regards
