LabVIEW and the AI coding revolution: are we being left behind?
@rolfk wrote:
@Yamaeda wrote: At least we should be able to get graphics cards and memory at a resonable price again. 🙂
Memory maybe. Graphic cards might be more problematic considering that NVIDIA is one of the AI hype drivers too and would loose a lot of hot air capital itself.
True, but graphics cards also have memory and there would be a flood of used graphics cards on the market. Didn't Grok buy 500 000 cards!?
Qestit Systems
Certified-LabVIEW-Developer
Message 31 of 38
(1,263 Views)
This will never happen, but I would love to see something like a .xVI file format.  Basically, a VI in XML format that the existing LLMs can understand and even write.   Would be awesome for version control diff'ing as well.
It'll never happen, as it would allow the possibility of an open source version of LabVIEW to be developed, etc.  I suspect NI feels the key's to the kingdom are those binary .vi files.
IMHO LabVIEW's strengths are (these will be different for everyone)
  • Low Entry Bar.  You can do meaningful work without a CS background
  • Ease of multi-threading.  Useful for work naturally parallel tasks like data acquisition and signal analysis.
  • Test and Measurement Driver Ecosystem.
This AI revolution threatens to negate the first two (and arguably all three) of their strengths and perhaps even make them weaknesses.
They are not an AI company.  Nigel appears to be too little too late.  I wonder if they are struggling to afford the required compute (and that's why key working features I saw like three years ago at NI week have never been released)?  NI's closed ecosystem forces them to do all their AI work in house and likely foot the bill for a LOT of compute.  This puts them at a huge disadvantage.
I think the correct vision is to open up the environment.  Long term they WILL loose LV revenue as 3d party tools and applications fork and spring up.  But they can position themselves to remain in control of the product.  Choosing LV over something like Python is becoming a harder and harder sell.  I don't like it one bit.
If the environment is open, they can ride the wave rather than be drowned by it.
My plan B would be to release the Nigel models and allow users to run it on their own hardware.
Well, really NI is really a hardware company.  Reckon LabVIEW is only about 15% of their revenu?  They might could do it.
But it'll never happen.  But projects like lvKit give me hope.
Message 32 of 38
(1,186 Views)
Have you tried the LabVIEW MCP yet? The results are really good.
An MCP offers the best way to build your own AI workflow exactly the way it suits you.
See:
https://forums.ni.com/t5/LabVIEW/LabVIEW-MCP-Released-Use-Claude-GPT-Copilot-to-create-analyze/td-p/...
https://discord.com/channels/1015999107921354932/1553399078602154159
https://github.com/Zuehlke/labview-mcp
https://github.com/Zuehlke/labview-mcp/releases
Best Claude
CLA / CTD / LabVIEW Champion
Message 33 of 38
(1,152 Views)
@Yamaeda wrote:
@NI_LV_82_User wrote:
I think that there is very high value in a noob like me typing “build me a “Hello World” vi and AI returning just that.
Now add seamlessly integrating TestStand, DIAdem, SystemLink, Flexlogger, etc.
For most such questions i think the Example Finder is golden! As for AI i had good help of ChatGPT last week in solving an issue and i could paste a screen dump of the code and it interpreted it pretty well. (It got some things wrong, but after corrections from me i got a good suggestion that actually solved my issue)
I had the exact same experience with ChatGPT. It explained what to get, where to get it, where to put it, and how to hook it up pretty good.
Bill
CLD
(Mid-Level minion.)
Message 34 of 38
(1,121 Views)
LV NXG was XML based You would've thought that making it text-based would make it easier to use versioning software, but you needed up needing to mark the VIs as binary anyway because versioning software loved to do freaky things to the XML.
Bill
CLD
(Mid-Level minion.)
Message 35 of 38
(1,116 Views)
It's been a bit since this discussion started.
I'm just curious:
  • Is anyone using Nigel for actual production work?
  • Is anyone using Claude or GPT with an MCP server like the one created by Cloedu72?
Message 36 of 38
(997 Views)
See:
Best Claude
This has an insane amount of promise.  Looking at GitHub, they are very active in it's development.  I'll give it a try in a sandbox.  Many thanks!
Message 37 of 38
(982 Views)
It doesn't work like that as people had to find out. XML may be text but it also has an inherent structure that can result in a single tiny change in the beginning, causing text being changed 1000s of lines later. And any non-trivial change to that structure requires an understanding of the actual format to be able to do proper diffing.
Even sequential programmed text is not entirely safe from that, as some changes can be rather difficult to be properly tracked without manual hand holding when it is about trying to merge two different changesets together. GIT by default doesn't even try to. If a local file has changes while the remote has some changes too it simply aborts when you do a pull, and refuses to do a push altogether. And that is just for sequential text programming where changes are often very localized and don't overlap in many cases. For XML it is actually more than just understanding the whole XML structure. A merge tool would need to be fully aware of the actual schema for the XML format to be able to safely merge two changed files.
Rolf Kalbermatter  My Blog
Message 38 of 38
(820 Views)
