LabVIEW and the AI coding revolution: are we being left behind?
@NI_LV_82_User wrote:
I think NI should be pouring in every resource to get AI to or above the level of AI & text code…
I believe the AI revolution is heading toward a dot-com-style crisis. We will likely see a major correction once it becomes clear that the massive investments in server infrastructure and compute capacity are failing to yield the expected return on investment (ROI)
That said, I still think LLM-powered AI is a fantastic way to revolutionize how search engines work.
Message 21 of 38
(1,203 Views)
I have a similar feeling. Except that the dot-com crash will look like a kindergarten party in comparison. We are talking about a scale of at least 1000 to 10000 in comparison to dot-com and while real inflation has been quite significant since, that's not even close.
Rolf Kalbermatter  My Blog
Message 22 of 38
(1,191 Views)
At least we should be able to get graphics cards and memory at a resonable price again. 🙂
Qestit Systems
Certified-LabVIEW-Developer
Message 23 of 38
(1,182 Views)
Hi All,
I just wanted to toss in my “noob” thoughts…
I am not a coder…
I am not a LV programmer…
I use LV all the time…
I like graphical (my A_D_H_D/dyslexia/visual-perceptual learning challenges favor pictures over words)…
But…
Problem is that not being a coder means you simply cannot maintain what the AI gives you. It's incurring lots of technical debt which only makes you more and more reliant on AI to continue producing code for you that you cannot maintain. In a way, you are making yourself completely dependent on AI for your tools. Price gouging by the AI providers will be the next step, and how many people will just have to fork out because they have no other alternative? Because they have prompted themselves into a corner?
The application you describe is exactly where I do NOT want NI investing money.
Message 24 of 38
(1,163 Views)
Hi All,
I am not a coder…
But…
There's going to be some sort of balance that shakes out. This same argument could've been used when people stopped writing assembly code.
The other thing too is that not all applications NEED to be maintainable. There are tons of programs out there that get written to support some specific test, and they stay relatively unmodified for years and years. When there IS a need to update something, often the original developer isn't around anymore anyway. If AI can handle some of that low-hanging fruit, it's going to be a VERY useful tool.
Message 25 of 38
(1,157 Views)
Big difference that you don't need to pay for tokens for each and every compile. You're not making yourself reliant on an outside service. It's the dependency on an outside entity that is questionable. I've nothing against the AI per se, it's the business model that worries me.
Message 26 of 38
(1,155 Views)
After using copilot and claude on python and C++ for the past few years going back in to maintain LV projects is downright painful.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 27 of 38
(1,118 Views)
Couldn't agree more, I have been using Claude and GitHub Copilot in Python and thinking of maintaining an equivalent large project in LV is not easy
Santhosh
Soliton Technologies
Message 28 of 38
(1,113 Views)
Found something that may be relevant.  I am in no way affiliated with them, but they guys at Pragmatest have an interesting project over at:
https://pragmatest.com/lvkit
and
https://github.com/pragmatest-dev/lvkit/tree/main
Looks like these guys have made a decent tokenizer for LabVIEW VIs that does not use LabVIEW.  Apparently, they developed this thing in a cleanroom w/o LabVIEW even installed.
I've been using it for my projects, made a few custom skills in Codex with decent success.  Basically, I let LVkit parse my fairly large project (around 3000 VIs) and point the LLM to the cache structure it creates, and simply ask it questions.  Granted, it's read only.. but...  It seems to understand my project.  Shoot, I'm using it as an ancillary tool to write my git commit comments (with an additional skill).
They are also working on a LV to python converter and they do work with generating SVG images from the VIs which I'm not really using much.. but the XML output seems to be gold.
Frankly, I'm not having much luck with Nigel.  It's slow, and the limits get me... but this thing is the first AI tool for LabVIEW that I've personally seen that has promise.  right now, it's what I wished Nigel was (well, meaningful code generation would be nice one day)
Figured I'd share.
Message 29 of 38
(1,026 Views)
Memory maybe. Graphic cards might be more problematic considering that NVIDIA is one of the AI hype drivers too and would loose a lot of hot air capital itself.
Message 30 of 38
(934 Views)
