LabVIEW and Parallele Port
Is there any way of communicating with the parallel port of the PC using
LabVIEW?
Thank you.
(1,609 Views)
> LabVIEW?
Yes, use the serial VIs. You will also need to
make changes to the .ini file to add the COM
ports to the list of ports. I don't have the
details in front of me, but I believe that
this is documented in the manual and on the
web site.
Greg McKaskle
(1,609 Views)
Since it's actually not that easy to find, here's the alteration to the .ini
file:
Append:
serialDevices="COM1;COM2;COM3;COM4;COM5;COM6;COM7;COM8;
COM9;\\.\COM10;\\.\COM11;\\.\COM12;\\.\COM13;LPT1;LPT2;"
(as one line)
Rick
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(1,609 Views)
