08-01-2017 01:46 PM
Is there any way to section off an area of pixles and dedicate them to LabVIEW in a way that will make the computer behave as if it had a smaller resolution?
For example: If I have a 16:10 Aspect ratio monitor with 16N X 10N pixles, I'd like to take the bottom 16NXN Pixles, run my vi inside that area and tell windows to behave as if the screen is now a 16NX9N Display. While the mouse could move freely between the two sections, the Start Menu would sit above my .vi and any program/browser started by windows that went to Fullscreen mode would only take up the 16X9 aspect ratio.
08-01-2017 03:04 PM
You're talking about altering the way that Windows does windows. This is definitely the wrong forum for that. I suggest you find out if it is even possible to do something like that, either by calling an EXE file or a DLL file or something similar, to activate that mode. Once you have found out that it's possible, then come back here with your questions about doing it with Labview.
