03-05-2019 10:52 AM - edited 03-05-2019 10:56 AM
Hi All,
Does anyone have an example of the "Challenge" VI we are supposed to create in the OOP training, section 3-4, "Dynamic Dispatch Tester.vi:"
"Create a VI that builds an array of Sounds using Generate Tone, Generate Silence, and so on, and then dynamically dispatches Generate Waveforms.vi to create a single waveform graph that contains the sounds that you configured." "Save the VI as Dynamic Dispatch Tester.vi"
I cannot download any software through my company's firewall, so if you could just post an image of the block diagram, that would be helpful.
Thanks!
Solved! Go to Solution.
03-05-2019 11:22 AM
I found an example.
03-06-2019 09:39 AM
To help future readers, could you point us to this example?
03-06-2019 10:04 AM - edited 03-06-2019 10:05 AM
When you extract the zip files from the NI download, the vi is located here:
...\2012_OOP Exercises_Solutions\SolutionSource\Exercise 3-4 Challenge\Sound Demo Support Files\Dynamic Dispatch Tester.vi
