01-17-2019 01:41 AM
I have a big problem with LabVIEW NXG 2.0 in WIN10. It not detect my hardware conected to PC in 'System Designer' . I conected NI-9215 via NI USB-9162. For compare I have the classic version of LabVIEW 2018 and it works OK with my DAQ card - (detect, test), all is OK. My computer recognize DAQ card, react correctly after conection. MAX detect my hardware. Problem is only in NXG version. When I open system designer and check USB to read and list conected devices - NXG not detect any USB hardware. Also, I dont check and open the USB icon. It does not highlight. Other icons (Network, Serial) work properly.
I updated all software and the problem still occur.
Screen of system designer with conented card below.
01-17-2019 02:19 AM
Screen (I can't highlight the USB port) :
01-21-2019 11:10 AM
Hey Criso,
Unfortunately, the NI USB-9162 is a legacy device that is not supported in LabVIEW NXG. To find out which NI DAQ devices are supported in LabVIEW NXG, you can look at the LabVIEW NXG Support and Considerations portion of the DAQmx readme for the version of DAQmx that you are using.
For example, with LabVIEW NXG 2.0, you are most likely using DAQmx 17.5 or DAQmx 17.6. Here are the readmes for those versions of DAQmx:
You can find readmes for all versions of DAQmx by selecting the version on the NI-DAQmx Download page, and clicking the link "View Readme", located next to the version selection box.
