LabVIEW LCD (16x2) with DHT11 (LIFA)
Hi, please refrain from using LIFA and use the LINX instead. That was the fix that I made use of. Hope it helps!
Message 11 of 14
(616 Views)
Great, I'll try it with LINX then .. thank you very much for answering, if I manage to make the file attached here
Message 12 of 14
(611 Views)
Great! I actually cannot attach a file myself so I wasn't able to share it with you guys.
Message 13 of 14
(599 Views)
I use I2C LCD1602 then it won't give the same result as you it. So what do I do when I have an I2C module?
Message 14 of 14
(481 Views)
