12-14-2020 09:53 AM
I am targeting a PXIe-7821R FPGA board and am using component level IP (CLIP) to instantiate and compile my VHDL source code within a timed loop operating at 64MHz. A 64kHz enable is generated with a Tick Count comparing the timed loop to 1000. This is fed into my CLIP's enable input.
At the end of compilation LabVIEW reports a failure due to timing violations. When I examine the timing violations, the timing constraint shows a 15.625ns period as expected with a very long combinational path between the source and destination with a total delay of about 50ns. This is expected. However, when I create a multicycle path constraint and save it in an xdc file, the constraint seems to get applied (because it doesn't show up in the unapplied_constraints report), but timing still fails, almost as if the timing analysis doesn't take into account the multicycle path constraint. Other constraints which I know have errors in the same xdc file are not getting applied as expected, so I know the same xdc file is being read.
Here is the constraint:
set_multicycle_path -from [get_pins -hierarchical -filter {NAME =~ */u_AZ_FPGA_inst/Goto3_bypass_reg*/C}] -to [get_pins -hierarchical -filter {NAME =~ */u_Analog_Dithering*/u_MATLAB_Function/*/*D}] 5
set_multicycle_path -hold -from [get_pins -hierarchical -filter {NAME =~ */u_AZ_FPGA_inst/Goto3_bypass_reg*/C}] -to [get_pins -hierarchical -filter {NAME =~ */u_Analog_Dithering*/u_MATLAB_Function/*/*D}] 4
I have compiled the design in Vivado 2019.1 using the source code produced by LabVIEW FPGA in the source_files directory. These files are encrypted vhd files. The use of the constraint and apply_constraints followed by update_timing shows a slightly different path that also fails timing, The path shows the source is prior to the Goto3_bypass_reg flip flop specified in the constraint.
When I look at the toplevel_gen.twr timing report, the path shows the correct source and destinations, but a failing path, as if the multicycle path constraint isn't getting applied during timing analysis.
How to I ensure that a multicycle path constraint is used during timing analysis, so that the compile process doesn't fail and so a bit file is produced?
12-15-2020 10:47 AM
Although I have not been able to understand why the tools didn't seem to analyze the compiled design against the multicycle timing constraint I gave it, I have found a work around solution that may be better. I have 'partitioned' the design into two single cycle loops to separate the clock domains per the recommendations in the online help here "Using Single-Cycle Timed Loops to Optimize FPGA VISs (FPGA Module)". This allowed me to clock the slower loop at 1/10th the clock rate and meet timing.
