Hi all.
i'm trying to use the FLIR file SDK with labview in order to open a FLIR thermal file.
according to this FLIR knowledgeabase it should be possible .
but whenever i try to load the .NET assemblies into Labview 2018, i get the following answer
An error occurred trying to load the assembly
i have tried to re-compile the .NET assemblies from the source, and i have tried to use the method described in this knowledgebase (by NI) to no avail.
has anyone ever tried (or even managed) to read a FLIR thermal image file (.ats) before?
or does anyone has any idea what am i doing wrong with my tries to import the .Net code into labVIEW?
thanks in advance 🙂
