06-25-2019 04:37 AM
No sorry Space constant.vi is the space constant, I'm using in the same Vi as Get LV class so I got confused
06-25-2019 04:42 AM
I used to be able to load my project!
My PPL are not saved in my repo.
I tried what you suggested, Creating a new project allow me to add all the elements. I can build the PPL but next time I open the project it crashes.
06-25-2019 05:17 AM
Still, it shows up in relation to broken VIs in the crash report...
Not sure how, why, or what to do about it, but it seems relevant. But perhaps it's not.
06-25-2019 05:21 AM
The crash report also warns several times about:
DWarn 0x2AD6ED36: gUnattended: (LabVIEW: (Hex 0x625) You cannot load a packed library built for a target or operating system different than the current target or operating system.
Are you sure all PPLs are recompiled to 32 bit?
06-25-2019 06:58 AM
The PPLs have been recompiled in 32bit.
This project used to be in 64bit and now I want to open it in 32bit because one of the dll( from a 3rd party driver) I have to use is not available in 64bit.
Usually LabVIEW doesn't close violently after a Ppl or dll is not in the right versions.
Journal.ctl also appears in every error report; it is the type def of a class. I've tried to rename the class with no effect. I am now considering rewriting this class.
06-25-2019 07:51 AM
I'd start by deleting\renaming the PPLs one by one. Sure, than LabVIEW can't find them when loading, but if it's not crashing, it might lead you to the offending PPL.
06-25-2019 08:07 AM
I have done what you suggested and if the PPL Journal is not loaded, it is fine.
I will rewrite the code of the class journal as this is the class that reappear the most in the error file.
06-25-2019 11:01 AM
I rewrote this part of the code and all the projects have been loading fine since.
The problem was with class Journal and its control.
Thank your for your help!!
