10-03-2014 10:26 PM - edited 10-03-2014 10:39 PM
I have had Labview downloaded for quite some time now. Downloaded control design and simulation module. Installed it. When i go to use it in the
functions menu, only the window appears. Opening it shows an empty window. I have attached a screenshot of the issue. Could someone please explain to me what the problem is and how I can go about fixing it?
10-03-2014 11:35 PM
Is the suite correctly activated? (Maybe the evalution period has expired)
10-06-2014 04:56 PM
As Altenback said, It is very possible it expired or it needs activation. To see for sure, go to your "NI License Manager" and expand the Modules. you should see:
If not green then you have to fix the license.
