LabVIEW Application Builder Crash : ntdll.dll faulting module
Hello guys,
I'm currently experiencing problems while building my project (LV2012 (32 bits) , Windows 7). At the very end of application build, LabVIEW crashes with no explanation (Screenshot in french, sorry)
Windows error logging follows :
Event 1000 Application Error
Faulting application name LabVIEW.exe, version : 12.0.0.4024, time stamp : 0x4fea600e
Faulting module name : ntdll.dll, version : 6.1.7601.17725, time stamp : 0x4ec49b8f
Exception code : 0xc0000374
Fault offset : 0x000ce6c3
Faulting process id : 0x16fc
Faulting application start time : 0x01cda5350f41f87c
Faulting application path : C:\Program Files (x86)\National Instruments\LabVIEW 2012\LabVIEW.exe
Faulting module path: C:\Windows\SysWOW64\ntdll.dll
Report Id : 8e5b1344-1128-11e2-97d8-c0f8dae81bad
I had the same problem on LabVIEW 2011. I tried to build my application with another computer (also LV2012 32 bits and Windows 7 64 bits) and I do not have any error.
What is wrong with my computer?
For french people, topic in french
Thank you for your help,
Quentin
(4,556 Views)
Accepted by topic author QuentinB
Solution found :
-Uninstall all NI products
-Clear registry keys related to LabVIEW
-Delete National Instruments directory into Application Data
-Reinstall LabVIEW
(4,542 Views)
