LabVIEW 7.0 Crashes when inserting "Instrument I/O Assistant" Express VI
sayaf,
You can download the latest version of NI-VISA for Win2k at the following link.
http://digital.ni.com/softlib.nsf/websearch/F20288844692F8D086256EE6006983D8?opendocument&node=132070_US
Has the IIOA ever worked on your machine or is this the first you have tried to use it?
Brett
Message 11 of 17
(1,007 Views)
Thanks Joe,
I already tried it Uninstalling/Installing many times but it didn't work
Sayaf
Message 12 of 17
(1,001 Views)
Tommy,
No i didnot install from driver CD, i downloaded it from web & installed using IIOA.msi file.provide me the link for the latest drivers so that i can reinstall properly.
sayaf
Message 13 of 17
(1,004 Views)
Sayaf,
I just ran the same IIOA installer that is available for download on a clean Win 2K machine, and it all seemed to install correctly. As I mentioned in my last post, there are several components missing from your MAX directory - I will list them here so you will know what to look for:
1) VISA - if VISA is properly installed, you will see visa32.dll in your C:\Windows\System32 or C:\WINNT\System32 directory. You should also see a file named niVISAui.mxx in your \National Instruments\MAX\UI Providers\ directory. This is how we can tell VISA is not installed on your machine by looking at your MAX directory.
2) The Assistant Framework - this component is what the I/O Assistant is built on. If it is not present, then IIOA will not work. You can tell that it is installed because there will be a mxwTask.dll in your \National Instruments\MAX\ directory, and that is not there on your machine, either.
So something strange is happening here - Let's take a look at what the installer is doing:
When you run your IIOA installer, you should come to a tree that lists the different products that will be installed. You will see under "Instrument Control" - VISA, NI 488.2, and Instrument I/O Assistant. Then you will also see a "NI Measurement and Automation Explorer 3.0.2". You can tell if the installer "thinks" these different components are already installed or need to be installed by selecting the item in the tree and reading the text to the right of the tree - it will say something like "This feature will remain on your local drive" if it is already installed, or "This product will be installed" if it is going to install it. When you start over after uninstalling everything, what text is shown when you select VISA? Does the installer think it is already installed? Or does it say it is going to install it?
Another helpful way for us to tell what the installer is doing is for you to log what happens during the installation - you can do this by running the installer from the command line with the following syntax:
"C:\National Instruments Downloads\IIOA\1.0.1\setup.exe" \l*v c:\log.txt
This is assuming you downloaded the installer to C:\National Instruments Downloads\IIOA\1.0.1\. After doing that, attach the log.txt created during the installation and we can try to see why the installer is failing.
-Tommy
Message 14 of 17
(992 Views)
Tommy,
Thanks for detailed reply but i want to clarify some other things such as can i use Tek visa instead of NI visa, from where can i download the latest IIOA & while installing IIOA.msi i don't get a tree.
Sayaf
Message 15 of 17
(983 Views)
Sayaf - Now I think I understand.
- There is only one version of IIOA available for download off of the web - it is version 1.0.1, which I am assuming is the one you are using. The link to it on the NI website is
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/f3ca0298c715bcd886256e82005758e5?OpenDocument
There is a version 1.0.2 with a couple of bug fixes, but it is only available on the latest Device Driver CD, and is not available for download.
- You cannot just run IIOA.msi. You must run the entire distribution included in the download from ni.com. The IIOA.msi has many dependencies that are included in the downloaded distribution. Download the installer I gave the link for above, and run setup.exe instead of IIOA.msi.
This should solve your problem.
- No, Instrument I/O Assistant does not work with Tek VISA. It only works with NI VISA because it uses quite a few of the features that NI VISA provides in MAX. What is your reason for needing Tek VISA instead of NI VISA?
Hope this helps.
-Tommy
Message 16 of 17
(980 Views)
Hi Tommy,
I think the problem was in installing IIOA,I'll try to install from the setup.exe file. Hope this time it might work.
Sayaf
Message 17 of 17
(970 Views)
