LabVIEW 2019 SP1 on Ubuntu Linux 18.04
I have  a licensed copy of LabVIEW 2019 SP1. Whether we can install this on Ubuntu Linux 18.04 . If yes, Please provide the installation steps. Also I would like to know whether the licensed version of LabVIEW is different for Windows and Ubuntu.
Thanks in advance.
(1,693 Views)
NI only started supporting Ubuntu installations with LabVIEW 2021SP1 as you can see in this chart.
https://www.ni.com/en/support/documentation/compatibility/20/labview-and-linux-os-compatibility.html
I did install older versions of LabVIEW 7.1, 2009SP1 in older versions of Ubunty (12, 14) and it is possible but not trivial as you need to convert the provided RPM installer image into a DEB one and then often also install some extra support libraries from the Ubuntu servers to provide the necessary functions used in some of the installer scripts. I have however no experience with more recent LabVIEW versions and Ubuntu 16 and higher.
However each version of LabVIEW is potentially slightly different and each version of Ubuntu definitely, so there is no single recipe that will work.
Rolf Kalbermatter  My Blog
(1,658 Views)
Thank you Rolf. So I have to upgrade my LabVIEW to 2021 SP1.
Don't know whether it's possible to upgrade rather than to buy a
fresh version of 2021 SP1.
If you have any information on this, please share.
Thanks for your valuable time and information.
(1,634 Views)
Accepted by JosephAlex
With the demise of LabVIEW perpetual licenses and the introduction of LabVIEW subscriptions begin of this year, there doesn't exist something like an upgrade anymore. When you buy a subscription you gain for the duration of that subscription access to the current LabVIEW version and earlier versions. Once the subscription ends, LabVIEW will not startup anymore. There is going to be some change in the future that you will at least get the option to startup some version of LabVIEW to be able to look at your existing VIs and maybe even run them. But saving and/or building of executables will be disabled in some ways without a valid subscription license.
(1,619 Views)
OK. Thank you so much.
(1,603 Views)
I guess we should've seen this coming when LabVIEW Community Edition came with a subscription license.  We were being used as guinea pigs to work out the kinks before they went live with it.
Bill
CLD
(Mid-Level minion.)
(1,586 Views)
