02-11-2019 03:13 PM
I have a small test application written in LV 2015 that I am trying to get to work on a panel PC with Windows 7 Embedded. I made an installer that installs the run time engine and my program. The install goes fine but when I try to run my program I get "System error 998 while loading the LabVIEW Run-Time Engine C:\Program files\[...]\lvrt.dll"
Is there anyway I can get this to work on Windows 7 Embedded or does LabVIEW just not work with it?
02-12-2019 08:55 AM
The only weirdness I am doing is disabling SSE2 optimization because the target doesn't support it. Any help would be appreciated.
02-12-2019 11:54 AM
Did you restart after installing the run-time engine? I've seen times when I ignored that step and the program would run, partially, or act weird until a restart.
Can you run any programs? Try making a hello world or some kind of test that isn't your whole application and see if that runs.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-12-2019 12:54 PM
Yes I restarted and this program is basically hello world. There are just a couple vis that are mock up screens of my application. I also tried uninstalling all NI software and installing the run time engine by itself then my application but always the same error.
02-13-2019 08:16 AM
I have successfully used WES7 PC's (from several different vendors) using LabVIEW 2011 SP1. Doesn't help you with 2015 other than showing it has run on previous versions.
03-01-2019 02:16 PM
Everything I have read indicates that LabVIEW should work on WES7 providing the right packages are installed, but I don't know what those packages are. I don't suppose you remember which packages were installed for Windows?
03-04-2019 07:14 AM
Hi StevenD,
I have a question. Was the application developed in Windows 7? If not, this might be the issue.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MeUSAU&l=en-US
-Enhernan
03-04-2019 03:14 PM
It was not. It was done in Windows 10. I got ahold of a Windows 7 machine and tried to make an installer from that machine instead but I am still having the same issue, the run time engine fails to load.
03-05-2019 10:59 AM
Before running the installer on the W7S. Were you able to run it in the Windows 7 machine? Have you tried in other Windows 7 machines?
