LabVIEW 2012 used to hang at shutdown, now hangs at launch ("Initializing menus")
Highlighted
I'm running Windows 8 64-bit, and have LabVIEW 2012 32-bit (12.0f3). I started using it a few days ago, and was never able to shut down LabVIEW properly. I could close my projects, but when I then tried to exit LabVIEW from the home screen, the GUI simply stop responding, and I'd have to forcibly kill it. Then, I installed the latest VIPM, and noticed that I can't shut that down properly either (I believe VIPM is implemented in LabVIEW?). None of my non-LabVIEW-based programs have this issue.
Then, I tried to install OpenG from within VIPM, which launched LabVIEW itself. However, that hung at "Initializing menus".
I'm not sure if VIPM had anything to do with it, but now, I'm unable to start LabVIEW altogether. Even after restarting my machine (using the Restart option, not Windows 8's Hybrid Boot), LabVIEW would hang at "Initializing menus". Task Manager shows 0% CPU activity, and LabVIEW had only taken ~20MB of memory.
What could be the cause, and how can I fix it?
Certified LabVIEW Developer
Message 1 of 14
(2,626 Views)
Highlighted
Another symptom: I attempted to uninstall all National Instruments software, and it runs into an error at: "Currently Removing NI LabVIEW FPGA Xilinx 13.4 Tools - Part 9 : Part 1 of 497."
Exception
The system cannot find the file specified.
'RegDeleteKey'
Message 2 of 14
(2,610 Views)
Highlighted
Ok, I:
  1. Uninstalled ALL National Instruments, JKI, and IVI software.
  2. Rebooted
  3. Manually deleted residual NI, JKI, and IVI files/folders
  4. Cleaned the Windows registry of NI, JKI, and IVI entries
  5. Rebooted
  6. Checked Task Manager to ensure that no NI service eluded deletion
  7. Installed LabVIEW 2012 from the NI Developer Suite DVD (LabVIEW only -- no other components)
  8. Rebooted
  9. Launched LabVIEW
LabVIEW launches now, but I'm still unable to shut it down properly... 😞 One day it will probably refuse to launch too.
Some help please?
Message 3 of 14
(2,595 Views)
Highlighted
My guess would be the FPGA Xilinx tools are the root of your troubles.  See here for NI product compatability with Windows 8.   Did you turn off fast start?
"Should be" isn't "Is" -Jay
Message 4 of 14
(2,589 Views)
Highlighted
Thanks for replying, Jeff.
When installing, I deselected EVERYTHING, and selected only "Ni Development Suite Core" -> "LabVIEW 2012 (English)". So, I have no other modules, no FPGA support, no drivers, no patches, no Xilinx tools.
Anyway, I tried disabling fast startup, but LabVIEW still hangs at exit.
Does LabVIEW come with a diagnostics tool/troubleshooter?
Message 5 of 14
(2,572 Views)
Highlighted
I would suggest working closely with your local NI support team.  Most of LabVIEW has been tested out on Win 8 and is "Under Normal Support"  (That means they will fix bugs found - not quite the same as "no known issues exist")
I'm sorry but, you are on the (B)leading edge here... New OS's are usually that way.  figuring out what Microsoft really did is a lot more trouble than reading about what they thought they did.
I even coded a bug onceSmiley Wink
Message 6 of 14
(2,560 Views)
Highlighted
Will do. Thanks for the tip!
Message 7 of 14
(2,529 Views)
Highlighted
Accepted by topic author JKSH
It was my antivirus that seemed to be interfering! Disabling Avast! Free Antivirus 7.0 made LabVIEW behave properly.
Has anyone encountered something similar before?
Message 8 of 14
(2,485 Views)
Highlighted
I have exactly the same config and the same problem with Windows 8 and Avast 7.
Disabling Avast, I managed to close the labview's window.
Can you open examples ?
More information here
Message 9 of 14
(2,413 Views)
Highlighted
No, I couldn't open examples with Avast! running.
Avast! + LabVIEW = Hang at shutdown, Hang at examples
Avast! + LabVIEW + VIPM = Hang at startup
I haven't tried running examples with the antivirus disabled yet. I can try when I get home
Message 10 of 14
(2,398 Views)
