09-01-2010 09:18 PM - edited 09-01-2010 09:21 PM
In LabVIEW 2009 SP1 (I don't have 2010 yet to check it) there seems to be a minor bug in the connector pane palette.
One of the connector patterns appears twice, but when you select the second one, it shows up as the missing pattern.
Solved! Go to Solution.
09-01-2010 09:30 PM
Very interesting.
Actually LV 8.6 and LV 2010 appear the same way.
How come no one has ever noticed this before now?
09-01-2010 09:32 PM
I guess everyone else is using "proper" connector patterns instead of these crazy non-standard ones.
09-02-2010 04:33 PM
This was actually recorded under CAR # 116251 a long time ago. That being said, I can confirm that R&D is aware of it, but I have a feeling that it's rather low on the priority list...
09-02-2010 04:54 PM
So you must be using crazy non-standard connector panes, or you would not have discovered this bug. Right? Actuall this is a good catch for it to go unnoticed for this long.
10-09-2011 12:28 AM
I just noticed this bug and searched for it and found this thread.
This is still the case in LabVIEW 2011, seems a pretty basic fix not to do it for so long?
