LabVIEW 2009 SP1 - Incorrect icon in connector pane palette
In LabVIEW 2009 SP1 (I don't have 2010 yet to check it) there seems to be a minor bug in the connector pane palette.
One of the connector patters appears twice, but when you select the second one, it shows up as the missing pattern.
I'd post an image, but that function seems to be broken getting through my company's proxy server. So image attached (I hope).
One of the connector patterns appears twice, but when you select the second one, it shows up as the missing pattern.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(1,682 Views)
Very interesting.
Actually LV 8.6 and LV 2010 appear the same way.
How come no one has ever noticed this before now?
(1,675 Views)
I guess everyone else is using "proper" connector patterns instead of these crazy non-standard ones.Smiley Wink
(1,671 Views)
Accepted by topic author TroyK
This was actually recorded under CAR # 116251 a long time ago. That being said, I can confirm that R&D is aware of it, but I have a feeling that it's rather low on the priority list... Smiley Wink
Caleb Harris
National Instruments | Mechanical Engineer | http://www.ni.com/support
(1,639 Views)
So you must be using crazy non-standard connector panes, or you would not have discovered this bug.  Right? Smiley Wink  Actuall this is a good catch for it to go unnoticed for this long.
- tbob
Inventor of the WORM Global
(1,625 Views)
I just noticed this bug and searched for it and found this thread.
This is still the case in LabVIEW 2011, seems a pretty basic fix not to do it for so long?
Certified LabVIEW Architect * LabVIEW Champion
(1,335 Views)
