LabVIEW 17.0 Development system is not responding to windows
There is no file of name--- LabVIEW.ini  in the \Program Files (x86)\LabVIEW 2017 in my PC. what to next? Any other solution.
Message 11 of 24
(1,640 Views)
You mis-read the previous suggestion.  If you are running 64-bit LabVIEW (besides the obvious question of "Why?  Most of us run 32-bit, as it appears to be more stable ...), you need to look in "Program Files" (where 64-bit apps are stored), not "Program Files (x86)" (which is for 32-bit programs).
Message 12 of 24
(1,630 Views)
In my PC the path is
C:\Program Files (x86)\National Instruments\LabVIEW 2011
So, I obviously forgot the "National Instruments" subdirectory in the full path.
Paolo
Message 13 of 24
(1,625 Views)
The default path depends on the OS and LabVIEW bitness:
LabVIEW 32bit on Windows 32bit: OR LabVIEW 64bit on Windows 64bit:
C:\Program Files\National Instruments\LabVIEW 2017
LabVIEW 32bit on Windows 64bit:
C:\Program Files (x86)\National Instruments\LabVIEW 2017
Message 14 of 24
(1,617 Views)
I know the path of directory i.e., C:\Program Files\National Instruments\LabVIEW 2017
But I am saying there is no file of name--- LabVIEW.ini which you suggest to rename.
what to do next? Any other solution.
Message 15 of 24
(1,610 Views)
The extension might not show, depending on your explorer settings.
However, if the file is really not there, maybe we have a permission issue and LabVIEW cannot write to that location for some reason. Do you have admin privileges? What happens if you start LabVIEW in admin mode (right-click...run as administrator)
Message 16 of 24
(1,608 Views)
Since every LabVIEW installation has a LabVIEW.ini file, it's possible that your file was eaten up by the same problem that prevents LabVIEW to start. Not a very useful info, though.
Paolo
Message 17 of 24
(1,605 Views)
I am having admin privileges, but i think LabVIEW configuration setting (.ini) file is missing in my C:\Program Files\National Instruments\LabVIEW 2017 folder. what should i do now to resolve this issue.
Message 18 of 24
(1,590 Views)
Message 19 of 24
(1,589 Views)
There is not much to do. If LabVIEW.ini is not there, LabVIEW simply creates a new ini file with a few default settings... if it can start of course.
Paolo
Message 20 of 24
(1,586 Views)
