I am attempting to test an executable that I have built. I need a clean environment so I am using Virtual PC. To run the executable I have to install the LabVIEW Run-time Engine on the VM. So I run lv82runtime.msi off the installation CD (found at D:\Products\LabVIEW_Runtime_Engine_82\lv82rte). Then I attempt to run the executable and it works. However I have a waveform graph on the front panel that does not show the signal I have wired to it. The graph shows up but there is no waveform on it at all.
I know the graph works because I have tested it before I built the executable. So then I tried creating an installer with the same executable that fouled up. I installed that on the same system and it works perfectly, even the wafeform graph.
So this isn't really a problem for me because I can simply create an installer instead of separately installing the LVRTE and then running my executable. But I still find it curious that the waveform graph doesn't work unless I build an installer. I can only guess that possibly there are a few libraries left out of the LVRTE.
Ideas?
Kyle
