12-15-2006 07:08 PM
12-15-2006 10:25 PM
Hiii christine,
Did you mean that the VIs with the MATLAB script are working fine in the other systems? because there is a default problem in the LabVIEW 7.0, there is a bug in the communication of LabVIEW with MATLAB in this verson of LV, this bug has been solved in the version 8 and after, so it could happen that thid could be a problem of this communication lack.
Pls tell me if these vis are working fine in another system, and it could also be a problem of LV installation, it is possible that LV is not installed properly.
Hope this helps.
Reply me with the positive reply.
Nishant
12-18-2006 01:56 PM
