01-29-2007 07:26 AM
I want to maintain the 7.0 version intact so I can maintain it during the transition.
(If my client calls with a small bug, I'd like to fix it in 7.0 and return it quickly).
After clearing up the still-hellish OPEN LLB FILES IN EXPLORER fiasco (this feature crashes my computer and has never worked for me), I have successfully compiled a portion of the code.
However, when I tried to run 7.0, and load the main part, lots of things were broken.
Mostly, it's DAQ-mx VIs and NI-CAN VIs.
They're just gone.
The whole MEASUREMENTS palette is empty, except for MOTION and VISION.
The CLASSIC DAQ palettes are gone (I use those for the RT board).
The MX palettes are gone. The NI-CAN palettes are gone.
The only thing I did in LV 8.2 was: Compile a portion of my code (after fixing a small problem with a property node), and MASS COMPILE the whole folder of my code (about 30 minutes it took).
Unfortunately, I didn't test the 7.0 stuff BEFORE I mass compiled, so I don't know if the installation killed it, or the compilation.
Or maybe it was that idiot EXPLORER feature. (the machine crashed 4-5 times before I was able to recover).
So, it looks like I have to wipe out LV 8, re-install LV 7, and start over.
But what should I do differently?
How do you get them both to co-exist, or is it just impossible?
Blog for (mostly LabVIEW) programmers: Tips And Tricks
01-29-2007 07:45 AM - edited 01-29-2007 07:45 AM
You CAN have both version of labview installed on one machine. The VI's will associate with which ever version was run last. If you compile your VI's to labview 8 they won't open with LV 7. If you need to keep a copy of the 7 version, save the entire heirarchy to a separate location and don't touch those files. Just opening a VI in LV 8 will recompile it and its subvi's to LV 8, if you save it your LV 7 versions will be overwritten.
As for the mass complie you did do, did you install all the device drivers for LV 8?
Message Edited by paulmw on 01-29-2007 07:49 AM
01-29-2007 07:49 AM
Hi Coastal,
The short story is
If you want to do anything more than just the core LV stuff (Drivers etc) you have to use seperate machines.
When new version of the drivers etc are installed they go through and delete all support for any version of LV is more than two release back!
I have four machines on or under my desk to support all of the variations of LV that I support.
I wish I was wrong!
Ben
01-29-2007 07:56 AM
01-29-2007 08:01 AM
LV 8.2 and 7.1 OK.
If you had LV 7.0 you would have seen the issue.
I REALLY REALLY REALLY want to be WRONG about this!
Ben
01-29-2007 08:05 AM
To be more accurate, when you install a new version of a driver, the old version with all its support files is removed.
If the older LV version can only use the old version, then it is left unable to do anything, because it can not use the currently installed driver.
I'm not sure what happens if both versions of LV support the new driver. If I remember correctly, you do have an option when installing the driver of selecting support for specific LV versions, but it's also possible that you have to play with it manually by installing to the lowest version and copying the files to the directory of the new version.
01-29-2007 08:12 AM
Yes, I know all that, but it has nothing to do with what I asked.
--MY-- code is OK, I'm wondering why LABVIEW's code has disappeared.
01-29-2007 08:14 AM
Arrrrgh. That looks exactly like what's happened. DAQmx, and NI-CAN just disappeared from the 7.0 setup.
01-29-2007 09:19 AM
01-30-2007 11:47 AM
