LV2017 Indicators are labeled as controls
I am not sure when this started but when I right click on an object and select "create indicator" it creates an indicator but labels it a "control".
Sure I am going to rename it anyway but for quick code checks it's nice to have it say what it really is.
=== Engineer Ambiguously ===
Message 1 of 15
(4,204 Views)
Are you seeing this for every item or just for the iteration terminal? I remember there being a bug report specifically for the iteration terminal.
Message 2 of 15
(4,173 Views)
This happens with numeric constants.
  1. Place a numeric constant on the block diagram,
  2. right click and select "Change To Indicator"
  3. It changes it to an indicator, but labeled as a control.
Message 3 of 15
(4,140 Views)
I wouldn't expect that change to indicator changes the name of the control after you place it. Was that different in another version?
Message 4 of 15
(4,136 Views)
LabVIEW 2017.
I placed a numeric constant and selected change to indicator, not a control.
Message 5 of 15
(4,131 Views)
In earlier versions, a numeric constant would have no label, but change to control or indicator and it would be labelled "Numeric".
0xDEAD
Message 6 of 15
(4,128 Views)
Maybe it's if the object in question is not labeled, changing it to or say popping up on the terminal of a sub-vi and selecting "create indicator" creates an indicator but labels it a control.
I will do some further testing
Message 7 of 15
(4,127 Views)
Okay it seems that it only happens on the iteration terminal and when changing an unlabeled Numeric Constant to an indicator.
I think I found a bug...
Message 8 of 15
(4,117 Views)
I just checked in LabVIEW 2016, 2015, 2014, and 2013 does the same thing.
Am I wrong in thinking that when you select a numeric constant and  "Change to Indicator" the default label for that numeric indicator would be "Numeric Indicator" not "Numeric Control"?
But it seems like it has been this way for a very long time.
Message 9 of 15
(4,113 Views)
Out of interest, what is your default style for new controls?
Message 10 of 15
(4,106 Views)
