LV2016 and Perforce
We use Labview to automate product builds from a repository under Perforce. Everything ran fine in LV2014. We recently upgraded to LV2016, and now have trouble getting a valid connection/reference.
We made a simple test bed that opens a source code ref, reads the p4 file status of a file in our depot, and closes the ref.  It works fine on LV2014. In LV2016, it says the same file, in the same workspace, is not "in  source control".
This test was repeated on two different Win7 machines, and on Mac as well. After digging through some of the low-level code in vi lib, I was able to fabricate a valid reference, and all the downstream source control vi's now function normally. It seems the only the "Open Reference" vi has a problem.
  I could not find any closely-related posts here.  I've attached a screen shot of my workaround. The two sub-vi's are "P4CMDSub Get Env info.vi" amd "P4CMD Open Project.vi".  We'd prefer not to call these directly, as the NI implementation  may change in future versions.
Has anyone faced this issue, and found a cleaner solution? Your thoughts and comments are appreciated.
Kevin M.
(4,163 Views)
I am sorry to hear you are having challenges with LabVIEW and Perforce.
I want to help but I have a couple questions first.
  1. Please tell me a bit about the sub vi's that have the SCC header. Did you make these,  I can't find them in LabVIEW.
  2. What is the "Open Reference" vi and where did you find it?
Anthony M.
Applications Engineering
(4,092 Views)
Anthony-
code snippets attached.
Hope this helps
(4,071 Views)
Thank you, this does help. I will look over it and get back to you.
Anthony
Anthony M.
(4,046 Views)
What version of LabVIEW do you have? I was getting this error (see attached) until i activated LabVIEW 2016 professional development system on my PC. Once activated, I am able to use the disabled portion of the vi you sent.
Anthony M.
(4,028 Views)
Hi Anthony-
We've been using the Perforce SCC functions in Developer suite in LV2011 and LV2014, and quite
possibly earlier. It's strange that it does not work in 2016, unless SCC functions are exclusive to the PDS in 2106?
Kevin
(4,012 Views)
Accepted by topic author wretched1
Kevin,
You are correct. Source control is available only with the Professional Development System as of LabVIEW 2015.
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-labview-to-use-source-control.html
Anthony M.
Anthony M.
(3,989 Views)
